1977 factory installed roof antenna,
square77
ontario
mark
GMC sierra 25
350 sb
1977 factory installed roof antenna, does anyone know if this was an option and if so how to fix one that is snapped off(I believe) just got it and can’t find any info on this.
Thanks
Strick
Dunn, NC
Harold
C20 Crew
There are fender & windshield antenna but I've never seen a cab mounted example. I've seen several aftermarket CB antenna holes though.
square77
ontario
mark
GMC sierra 25
350 sb
Thank you, thought aftermarket but truck has no headliner and there is no hole inside. I also removed the interior light to have a look. Thanks for the help. Happy to be a part of the site!
Strick
Dunn, NC
Harold
C20 Crew
I just welded a hole similar in my 87 V10. Sparks flying through the dome light LOL! Thankfully there's no headliner in it. It has the windshield antenna but I've used a 91 Sub clip & it's fender mounted.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I’m going to say that’s an NMO antenna mount, for a cb or public safety antenna. I don’t think GM ever did a factory roof antenna. The NMO can be installed from the top down, snaking the cable between the roof panels, so there wouldn’t be a need for a hole under the headliner. You can either place a weather cap on it, a new antenna, or remove it and fill the hole.
kobedemello
