1976 GMC C35 SM465 to GM ZF6
Playher
Buffalo WY
Patrick
V20
Hello, I found a GM ZF6 trans and it came with all the parts to convert including the clutch pedal assembly. I did not know they were made entirely of plastic. Question is, has anyone used this by simply connecting up the clutch master cylinder to the existing clutch pedal? Can I mount it underneath and use the Z Bar to actuate? Thanks
What motor is in the truck? I have not heard of anyone using the ZF6 on a classic small or big block (other than the bastard child 8.1).
I'm confused... what is made of plastic? The ZF6 was standard on most of the towing application with high torque like 8.1 and Duramax trucks, they are super beefy. If they bolt right up to an 8.1, they will bolt right up to any SBC or BBC
I would assume the clutch pedal and various bits from inside
Playher
Buffalo WY
Patrick
V20
Im putting it behind a 454. Hucked is correct, "plastic" I was referring to the clutch pedal and bracketry. I would assume that once calculating the correct throw/stroke, I could mount it anywhere in the mechanical linkage train and get the same result. I have scoured the internet for info and cant find any. Most posts lead back to a $1,000 conversion package for sale. I figure some redneck somewhere has already done this and hope to get some input. Also, having trouble finding pics of a 1987 c/k (v/r) hydraulic set up to look at so if any of you have that, I would appreciate it.
Thanks
pduffyd
Melbourne, Australia
A youtube search is a help.
Here is an example.
Playher
Buffalo WY
Patrick
V20
Well I finally did it. It bolts straight up. I got a hydraulic pedal set from an 89, built a bracket for the oe master so I could use the oe hose and have the correct bore and stroke. I got a new 454 flywheel and clutch /pressure plate for a 8 1 and it also bolts straight up. I'll have the tunnel done and interior back together in a day or two.
ArlenB
