1976 Chevyvan G30 stiff accelerator pedal
Brentdavis13
Indianapolis
Brent
G30
350 v8 Jasper
Hi there.
My Chevyvan G30's accelerator pedal is quite stiff to push when accelerating and also even when the ignition is off. The engine is a refurbished V8 with only 500 miles on it. The air filter is not old by any means. I wonder, is it the spring that the accelerator cable is connected to?
Does anyone have any tips?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Make sure the cable isn’t twisted or kinked, look for obvious damage. Unhook the throttle from the carb, does the carb throttle plates move freely? If not, try moving the throttle with it unhooked.
Find out why the throttle is stiff. Having a pedal that is hard to push is an inconvenience. Having a throttle that sticks in the open position is dangerous!!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Guarantee it's the cable. I switch mine to mechanical linkages. Probably not easily done on a van.
Brentdavis13
Indianapolis
Brent
G30
350 v8 Jasper
thankfully it doesn't stick! and I'm glad that is not a problem that I have to fix. I will check out your suggestions, thanks!
1lejohn
texas
john
k-1500, 2500 HD
My throttle pedal is also a workout for my right leg. On my application I think it's the angle the cable is in to reach the carb.
Danny55
