1973 Tailgate Trim Band Replacement
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
I have a 1973 K5 Blazer and trying to replace the tailgate trim band. Unfortunately, I have not been able to find a clean oem or reproduction one. LMC makes a tailgate trim band for 1981 thru 1991. Does anyone know the difference between a 1973 and 1981 thru 1991 tailgate trim band? Can someone measure their tailgate band, if you have a 1981 to 1991 Blazer or Jimmy?
My tailgate band measurements are 66 3/4" length and 7 1/2" wide.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
No difference in length, there’s slight manufacturing differences but your talking 1/16 - 1/32”
The later one has a stamped ridge around the perimeter, with a black painted boarder.
ali_c20
Austria
Alexander
C20, K5
You can restore your old one. It is in real good shape and can be done with a little elbow grease. The Chevrolet tailgate emblem is available at OER, LMC, etc.
https://www.gmsquarebody.com/threads/1973-blazer-tailgate-aluminum-panel-restoration.40736/#post-976882
JoeyPepperoni
