- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Does anyone know if the following parts are the same between the axles:
The metal gasket that goes under the axle shaft against the housing
The bolts that hold the axle shaft, I imagine one is SAE and one is Metric, but are they "the same" threads enough to be used in either
The cover on the pumpkin and the gasket beneath it (could a lubelocker gasket be used on either?)
