14 Bolt Semi Float Variations and Measurements
StraightTimeStirrups
So Cal
Joe
What is the bolt pattern on a 14 Bolt Semi Floating Axle? If its not a 5 x 5 can it be converted to that? Secondly, what are the various axle widths that came on these axles in both spring pad width and wheel mounting flange to flange (all variations including SRW and DRW)?
Joe
Welcome to GMSB Joe. This seemed to be more of it's own topic, so it's been moved accordingly, and should get more attention on it's own.
I'm aware of the only 5x5 wheel pattern comes in the GMT400 Body Style of the 454SS Pick up. Then there are the 6 & 8 lugs also available in the GMT400 Body Style, and Only 8 lugs in the Squarebody style
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I only have info on the full-floater and cant be much help here. Specs for the FF are...
SRW: 67.5"
DRW: 72"
C&C: 63.5"
Van: 70"
Not sure if these numbers will be the same between 14SF and 14FF but it might be similar and give you an idea what to expect.
SRW: 67.5"
DRW: 72"
C&C: 63.5"
Van: 70"
Obviously, this is overal width. From where to where??? Backing plate to backing plate? Or outside hub to outside hub or what??? :shrug:
:popcorn:
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
The 14sf found under a square will be very close to the width of the srw 14ff. As for the lug pattern, it is standard gm/ford/dodge 8 on 6.5.
5 lug 14sf axles were also used under some g20 vans.
goodwrenchca
