14 bolt newbie question.
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Please don't shred me here. I am in the process of tearing down my 87. I am going rear 14 bolt full floater shopping later next week. I know non dually, (or so i was told) My question is when i get ready to assemble the truck, does the full floater bolt right up in the same stock location? As in when I un-do my axel, do I unbolt it, roll it out of the way, and then bolt the 14 in the exact same location using my stock springs location?
Thanks,
Al
Auburn, Washington
Yes it will if you have a srw axle. Drw/chassis cab and van chassis are different.
If you’re curious, theres a comprehensive 14bolt write up floating around on the inner webs. Look for that. It’s very informative.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
The 1 ton srw axles have different spring perch width (40.5” vs 42”)and the shocks are reversed and located differently as 1 tons have the shocks inside the frame
The 3/4 ton axle shares the 42” perch spacing and shock locations with the 1/2ton
GorillaHumper
