14 bolt ff swr or c&c identification?
Whether it be from a 2wd or 4wd, 67" wms-wms should be fine.
Coaler02
Wisconsin
Carmen
V30
I picked up a 14 bolt ff with NON-slide on drums, pumpkin housing is ribbed top and bottom. (was told it was out of a 80s truck, unknown if swr or dually)
I've taken some measurements, below is what ive gathered:
WMS-WMS = 67"
Backing plate flange to flange = 54"
Shock mounts are 31" oc from each other
Leaf spring perches are 47" oc from each other.
The hub is a swr hub, not the dually.
I plan on using this to replace the 12 bolt truck axle, and understand that the perches would have to be re-welded. I just want to see if there is any other information I am over looking because this is my first axle swap.
Maybe this will help.
Svein Knutsen
Norway
Svein
Blazer K5
Hi been looking for info about codes stamped on the axle do any of you guys have that if and could post it
Strick
Dunn, NC
Harold
C20 Crew
I've got a 14FF under my '55 6100 Series that looks similar with the exception that mine has disc brakes. It's from an '04 3500 van. I moved the shock & spring perches & it fits. The overall width is wider & evens the rear wheels with the front.
Strickland
shannonhalsey
