Need ass much traction as possible for plowing, plowing up hills, hunting property ect... This is also a dump truck that needs to be able to carry heavy loads, and posi dually burnouts sound funWhat are you trying to do? Off-road, on-road, just burnouts? You can tell what the gear ratio is by looking at the numbers stamped into the outside of the ring gear. 41-11 would mean it's a 4.10:1 ratio.
Turn one wheel and see if the other wheel turns the same direction. If it moves the same direction you have a factory Gov-loc. If the other wheel turns in the opposite direction you have an open carrier.
The cheapest, easiest, and strongest option is to install a lunch box locker like the detroit or a Yukon Grizzly. They replace the spider gears inside the carrier and don't require you to change or adjust anything else if you don't want to. If you have a gov-lock, you have to either get an open carrier to install a locker or get a limited slip that replaces the whole carrier.
