Jawzjeep
Honk if parts fall off
- Jun 5, 2021
- Washington
- Joshua
- Suburban
I got a 14 bolt ff that came with a disc brake conversion on it already. Is it something I can simply swap between other 14ff's or is there work that's needs to be done to the axle to accept the conversion kit. Seems bolted to the axle. Might swap it to a different 14ff.
If it isn't obvious I've never done a rear disc brake upgrade either. Thanks
