12bolt axles worth 300 bucks?
coreys87
newyork
corey
v1500
Nike I have to pull the cover. I'm guessing around 3:90ish
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Standard ratios are 2.73, 3.08, 3.42, 3.73, 4.11, 4.56, 5.13 you wont find 3.90. The ring gear outer diameter should have the tooth count of the ring & pinion stamped on it, divide them together and you'll get your ratio.
As C4 said, its not 3:90. I'd say likley 3.73's. :waytogo: 3:90's were in the old old early sixties 1/2 ton trucks with drop out 3rd members.
coreys87
newyork
corey
v1500
Ok. Thanks guys I rotated the input shaft and it took 2 complete 360 degree turns to rotate the axle once so I figured around 4:10 ish
crazy4offroad
K-10
350/SM465/NP205
You should rotate the tire one revolution and count how many times the pinion or driveshaft spins.
Yep, you have a 4.10 peg legger if it spun just a nats ass over 2 full turns.
:rofl: I think he meant he turned the pinion yoke 2 full turns to the one of the axle Curt, Same/Same, its not an installed rear end yet, so I doubt it has tires on it yet.
coreys87
newyork
corey
v1500
Yep you got It horror. Guess my dad still knows a few things from back in the day lol guess it'll be better than 4:56's on the highway
crazy4offroad
K-10
350/SM465/NP205
I guess I read it wrong, like he turned the pinion one time and the axle/brake drum/whatever turned 2 times.
coreys87
newyork
corey
v1500
Now I wanna find a locker for it
rtomrdle
