10 bolt to Dana 44
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Quick question for everyone if I swap out my 10 bolt for a 44 do I have to change any steering components or spindles? I just did ball joint on my 87 V10 and found a 44 and a 14ff for 250 and don't want to have to redo ball joints again.
Sent from my XT901 using Tapatalk
The whole thing bolts in, but if you want to use your new ball joints, you can just swap on your current knuckles with the ball joints already pressed in. Or of your front axle is the same ratio as the new rear axle, you can just swap on the 8-lug parts and keep running your 10 bolt.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Alright thanks I didn't know if the spindles changed or if they were interchangeable
Sent from my KFTT using Tapatalk
You did good to get a 14B FF and D44 8 lug for $250. :waytogo:
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Haven't picked it up yet a buddy has it and I gotta source the cash. If I do get it though I don't think they will be put in until the lift. Due to the fact I'm gonna regear to 4.10 or 4.11 and need some 8 lug rims
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
You're going to regear the Dana 44 after you install it?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Plan on it yea. Its getting a 8 or a 12in lift so I'm going for stronger axles and don't feel like shelling out a grand for a 60 right away.
gtewolf79
