10 bolt cover
jaredpears
texas
jared
k10 suburban
Do the 10 bolt front and 10 rear axles use the same cover pattern?
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
I do believe there’s a section on here on that, have you tried searching axle identification in the forum by chance?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
No not the same. The rear is almost a perfect circle. The front is a circle with a flat spot at 12:00 - 2:00.
thatgermanguy
