Shack
- Nov 27, 2015
- North Carolina
- Mathew
- K10
Welding cast perches can be tricky, you have to use high nickel rod and cool the weld slowly or it will just crack at the weld. If it was me I would source another axle from a 3/4 ton, or buy some stamped perches to weld on. As far as driveline angle your tcase output and pinion angles should match or be close. If it looks like your tcase output points down a little your pinion should point up the same degree. This is why the front uses a double cardan joint. The tcase output up front just about always points up a little so 2 joints on the tcase side helps eliminate vibration.
Perfect. When the time arrives, I will refer back to here and ask again juts in case I forget. lol Thanks!
