1.4v at electric choke?
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
"if i unplug the wire from the choke i get 12.7 volts when the key is ON/Engine off, is it supposed to work like that too"?
"I still don't understand why I have 12v with the wire unhooked and very little voltage with it hooked up and engine off for both"
If I'm understanding this correctly, it sounds like the oil pressure switch has leaked/damaged internally, and is not passing/shunting voltage. That was one of the reasons for having the 'idiot light' (Choke or Oil/Choke) in the circuit.
The light is on when engine off but key on. That makes sense since it doubles as low oil pressure light.
Is it supposed to come on when choke active or inoperative?
Sent from my SCH-I605 using Tapatalk
flyboy1100
UsA
me
k1500
It should be shut at startup in the morning. Cold to an engine is 100 degrees.
Hmm, never seen it move, it was always locked open, I adjusted it a bit yesterday but it was hot, it does move a little now, will check tonight before I drive home
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
It is supposed to come on with the key on, engine off (everything intact). If the choke heater fails or is unhooked, it should be on when the engine is running (assuming there is oil pressure). If it is failed/unhooked when the key is on, engine off, I believe the light will be off (failing the bulb check function).
350runner
tx
Ceasar
Yes sir.
Boone83K10
Boone, NC
Benjamin
When the engine is cold, loosen the choke cap. Turn it until the choke flap is closed (don't crank it all the way as far as you can turn it)then tighten the choke cap back down. That is your initial setting for cold engine start. As engine warms it will open.
flyboy1100
UsA
me
k1500
I tried that but the linkage must be jammed. I even pulled the cap off tonight and still couldn't get it to close.
Voltage when running matches the battery so the switch must be working correctly, just the rest of the choke system is jacked up.
Boone83K10
Boone, NC
Benjamin
Some one has fudged it up.
350runner
tx
Ceasar
Remove the choke cap and move the choke manually. Watch the lever in the choke housing to see if it moves. If so then try to move that lever in the choke housing manually by hand to open and close the choke.
flyboy1100
UsA
me
k1500
lever doesn't rotate more than about 10 degrees by itself. i removed the entire choke assembly and even then the choke door doesn't move very smoothly.
is there a book or something i can read on this? i have no idea how to get this to work.
On most vehicles, an electric assist choke is incorporated onto the carburetor to aid in reducing the emissions of hydrocarbons (HC) and carbon monoxide (CO) during starting and warm-up (choke-on) period. The electric assist choke is designed to give a more rapid choke opening at temperatures of approximately 60-65°F., or greater and a slower choke opening at temperatures of approximately 60-65°F., or below. The electric assist choke system does not change any carburetor service procedures and cannot be adjusted. If the system is out of calibration, the heater control switch and/or choke unit must be replaced.
The main components of the electric assist choke system, Fig. 39, consist of a thermostatic coil, ceramic resistor, cover, bi-metal snap disc and contact spring. The electric actuated ceramic resistor heats the thermostatic coil, gradually relaxing coil tension and allowing the choke valve to open.
At air temperatures below 50°F., electric current applied to the small section of the ceramic resistor, allows slow opening of the choke valve for good engine warm-up. As the small section of the ceramic resistor continues to heat, a bi-metal disc causes the spring loaded contact to close and apply electric current to the large section of the ceramic resistor which increases the heat flow to the thermostatic coil for more rapid opening of the choke valve.
At air temperatures between 50-70°F., electric current applied to the small section, or both the small and large sections of the ceramic resistor, will produce the amount of heat required to control the choke valve position for good engine operation in these temperature ranges.
At air temperatures above 70°F., electric current applied to the small section of the ceramic resistor and through the spring contact to the large section of the ceramic resistor, provides rapid heating of the thermostatic coil for quicker choke valve opening when leaner air-fuel mixtures are required at warmer temperatures.
Diagnosis & Testing
Possible conditions for the electric choke not operating properly are listed as follows (use a voltmeter to check oil pressure and choke coil circuits):
1.Low or no engine oil pressure.
2.Faulty oil pressure switch.
3.No current to oil pressure switch due to:
a.Burned out fuse.
b.Broken wire to oil pressure switch.
4.No current between choke and oil pressure switch due to:
a.Broken lead wire.
b.Wire terminal not properly secured on coil terminal.
c.Faulty ground circuit between choke assembly and housing grounding plate.
5.Faulty choke coil assembly.
If it is determined that the choke coil assembly is inoperative, the following test must be made:
1.Remove choke coil from carburetor. After removal of choke coil, allow coil to cool to room temperature.
2.Connect a ``jumper'' wire between positive battery terminal and choke coil terminal assembly. Connect a second ``jumper'' wire between negative battery terminal and choke coil assembly grounding plate.
3.The tang on the choke coil should rotate 45°in 54-90 seconds.
4.If choke coil does not rotate or exceeds the 54-90 second time limit, replace choke coil.
5.If coil is within specification, check steps 1 thru 5 for possible cause.
Testing and Inspection
Many trucks utilize a warning light on the instrument panel in place of the conventional dash indicating gauge to warn the driver when the oil pressure is dangerously low. The warning light is wired in series with the ignition switch and the engine unit--which is an oil pressure switch.
The oil pressure switch contains a diaphragm and a set of contacts. When the ignition switch is turned on, the warning light circuit is energized and the circuit is completed through the closed contacts in the pressure switch. When the engine is started, build-up of oil pressure compresses the diaphragm, opening the contacts, thereby breaking the circuit and putting out the light.
TROUBLESHOOTING
On some models, the oil pressure indicator light also serves as the electric choke defect indicator. If Oil or ENG. indicator light does not light, check to ensure electric choke is not disconnected at carburetor. Also check for defect in electric choke heater, blown gauge fuse or defect in lamp or wiring circuit. If indicator light stays on with engine running possible causes are: oil pressure is low, switch to indicator light wiring has an open circuit, oil pressure switch wire connector has disconnected or on some models, gauge or radio fuse has blown.
The oil pressure warning light should go on when the ignition is turned on. If it does not light, disconnect the wire from the engine unit and ground the wire to the frame or cylinder block. Then if the warning light still does not go on with the ignition switch on, replace the bulb.
If the warning light goes on when the wire is grounded to the frame or cylinder block, the engine unit should be checked for being loose or poorly grounded. If the unit is found to be tight and properly grounded, it should be removed and a new one installed. (The presence of sealing compound on the threads of the engine unit will cause a poor ground.)
If the warning light remains lit when it normally should be out, replace the engine unit before proceeding further to determine the cause for a low pressure indication.
The warning light will sometimes light up or flicker when the engine is idling, even though the oil pressure is adequate. However, the light should go out when the engine speed is increased.
flyboy1100
UsA
me
k1500
That's a good read, how about all the linkages behind the choke spring assembly? Is there supposed to be a vacuum diaphragm on the front? There isn't currently, no idea if there should be or not
350runner
tx
Ceasar
That fitting in the front is to assist the choke with hot air from the intake
flyboy1100
UsA
me
k1500
so if i have an all electric choke, i shouldn't have that? gotta make sure I'm not missing pieces before i did into this further.
350runner
tx
Ceasar
Nope sure don't :)
350runner
tx
Ceasar
I just cap it
BillChito
