mikeoverland
- Oct 24, 2021
- san antonio tx
- michael
- C10
- 250/I6
Yep, it's me again. Still working on the basket case (1981 250 I6) and for the life of me i can't figure out what carb should be on this thing. RIGHT NOW it has a 2 bbl varijet 2 that doesn't look like it belongs on the intake since it seems that someone made an adaptor out of sheet metal to put this carb on the intake. there is no code factory code sticker in the vehicle that list what the truck came with so i don't know if this engine is supposed to have a 2bbl or a single bbl carb. the air cleaner assembly fits the existing carb but tht means less than nothing. I have to pull the carb since it is leaking out of the bottom gasket and the bowl is full fo some sort of nastyness that can't be described. I refuse to rebuild the carb if it is the wrong one for this vehicle. Someone out there in net land has to have an 81 250 I6 integrated head motor or has seen a stock 81 intergrated head motor and knows what type of carb should be there. Please let me know.
thanks
thanks
