AP Guy
- Apr 24, 2018
- NE Iowa
- Dustin
- Sierra Classic
Alright, so I've been playing around with trying to troubleshoot my old daily driver that started to have some cooling issues. I started noticing the coolant gauge starting to move around and as time went on began to notice bubbling into the coolant overflow. That automatically made me think the head gasket finally blew. BUT, after running through a compression check all the cylinders came out ok. All were a bit low due to the mileage but all were within a few psi of each other.
I can idle the engine all day long and it seems to run just fine but as soon as load is put on the engine (ie: driving) it will overheat and coolant pressure feels crazy high and I can bleed the air out of it until I'm blue in the face to no avail so the coolant is getting air in it some way or another(boiling?) I did a coolant pressure check and I couldn't see any visible leaks, nor any noises or bubbling coming from inside the engine after pulling the plugs, opening the oil fill cap, putting my ear to the intake...nothing. I shut the air valve and pressure seemed to be holding as well. Oil is clean too.
I'm a bit stuck. Now my thoughts are potentially a failed water pump that's not circulating coolant? A failed thermostat?... even though a new one was installed with the LIM gaskets a while back that should fail open if it did happen to fail.
What am I missing?
What am I missing?
