- Feb 24, 2020
- Auburn, Georgia
- Zach
- Sierra 1500
So after work yesterday, I started back on the heads again. Made sure to put the lifter retainer bolts in and torqued, then re-cleaned the head bolt holes out real good.
Then cleaned the pass side head and the block gasket surfaces real good one more time, aligned the head gasket and head on the dowel and used 2 old head bolts screwed in just a couple threads to hold it while I put the ARP hardware in.
Here's the instructions just for those that are curious. Like I said, SO MUCH easier than the GM bolts
Then installed new grommets in the valve cover and tossed it on to close up that side and taped off the intake ports
