Wiring harness and random connector 1987 R10 305 TBI
gxrardo
Lexington NC
Gerardo
R10 Silverado
Hi just wanted to know what this connector is for. As well as if this wiring connection is factory or if someone else did it.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
That splice is factory. Proving once again that there is NOTHING wrong with soldering wires if properly done!!
I’m not so sure about the connector. GM normally uses weatherpack type connectors outside of the passenger compartment.
What color wires are in the connector?
gxrardo
Lexington NC
Gerardo
R10 Silverado
Looks like black and pink w black stripe
Tdabney
