Garage upgrade
WFarm
Central Virginia
K5 Blazer
Been manually lifting the 12 x 12 shop door and pulling a rope to close it for 10 years or so. Kinda a PITA coming and going but I was too cheap to pay for a door opener just for convenience as physically I had no problem raising and lowering it. Then last weekend we pulled up in the Blazer and the wife hopped out and said she’d raise the door. Took her two attempts so at that point I said enough.
I like it!
WFarm
Central Virginia
K5 Blazer
Let's see the hardware.
Two remotes, a wall unit inside the shop and an exterior unit that takes a pass code.
WFarm
Central Virginia
K5 Blazer
@idahovette the link below is for the manufacturer. They are made in Germany. They can be purchased from their website and will ship from Charlotte NC. Come with a lifetime warranty.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Dang it Paul....I was just thinking I needed to get a opener for the shop door, it is heavy. I know that you can adjust the springs, and in the past I have, but it was a little scary. No way I am doing that now. Dang, gotta get one..
WFarm
Central Virginia
K5 Blazer
Dang it Paul....I was just thinking I needed to get an opener for the shop door, it is heavy. I know that you can adjust the springs, and in the past I have, but it was a little scary. No way I am doing that now. I need, I need!
I mentioned the thread here regarding messing with garage door springs to the guy installing my opener. Great guy BTW, veteran, family business. Anyway he told me of a newbie who went after a spring with a short ratchet wrench versus a long bar. Thing wrapped his arm around the shaft a couple times and wrapped his shirt around his neck, choking him. He lived and kept his arm.
Sometimes it’s best to just write a check. o_O
I guess this falls under this category. I cleaned and rearranged the shop today. Put the Extracab cab over in the corner that just had a bunch of crap stored in it. Swept for what seems like for hours. Was going to mop but the wife called and asked if I'd make supper for her and her friend. Not done with rearranging but I have sooo much more room for activities. I did this with the thought of when I pull the Mistresses body back off so I can run fuel line, brake lines, and do the firewall. I can have the frame next to it.
wheelie-schizes
