Dually Rims
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
What newer model year rims will fit my 86 dually?
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
As long as it is an 8 on 6.5” with an appropriately sized center/register hole… You can run whatever you think looks good.
I have Eagle bullet holes on my 99 (gmt400) K3500 cab & chassis dually. Honestly, they look fine, but have a maximum 60psi rating. Fine for an old C20 or K20, or for a C30/K30 that no longer gets worked hard.
I’d straight swap them for Squarebody, gmt400 or gmt800 steels w/o a second thought. My K3500 needs to be on “farm truck” tires, like a 7.50-16LT Deestone 503, that don’t play well with alloys.
Auburn, Washington
Like he said any OE 8x6.5 from any of the big 3. Fords thru 97, GM thru 2012? Ish, Dodge through 2018 I believe.
Ram wheels will be 17” from 3rd and 4th gen trucks
Ford and Dodge wheels have a slightly larger center bore, iirc. The GM dually wheels are hub centric, so you would need center bore spacers with the Ford or Dodge wheels.
McNeal87
