Avs2 problems
liam
Seatle Washington
Liam
k20
I have a 1984 chevy k20 with a 350 and an Edelbrock 650cfm avs2 and after installing the avs2 it always seems to unadjusted itself i have had to adjust it 7 different times I dont think that is very normal
liam
Seatle Washington
Liam
k20
The ideal speed and mixture screws
ali_c20
Austria
Alexander
C20, K5
First check if your ignition is adjusted right and all it's components are ok. Check for vacuum leaks. No vacuum leaks and ignition spot on - adjust carb.
As already mentioned, check carefully for vacuum leaks and/or hoses off. Make sure the throttle moves smoothly and the linkage does not rub or catch on anything. Put the air cleaner back on, and check again for any binding. A stock air cleaner may not seat correctly on an Edelbrock because the fuel fitting on the passenger side gets in the way. Use an air cleaner spacer, if necessary, or buy the Edelbrock dropped fitting.
Adjust the idle very low (500-600 rpm) and with the vacuum advance disconnected and vacuum line plugged, adjust base timing to about 12 degrees. Then rev it up to about 2500-3000 rpm and verify you get about 18-20 degrees more for mechanical. Go back to idle and connect the vacuum advance line to full vacuum, and verify it also gets you about 18-20 degrees advance. All this shows that your distributor is working.
Take the AVS2 off and adjust the idle stop screw so that with the choke off and linkage at normal idle, you get a square transfer slot exposure. This will get you the best adjustability for mixture and off idle transition.
Warm up the engine and ensure the choke is fully off and it is at curb idle. Now gently turn the mixture screws in, and turn them back out the number of turns Edelbrock recommends. Then connect a tach or a vacuum gauge, and adjust the idle mixture for the best rpm. It should not take a lot of adjustment for a stock engine.
Carb'ed Vortec 350
When I bought Crusty Biscuit the PO had installed an avs2 on it. I was constantly readjusting it. Since I had a spread bore intake and a ready to go quadrajet, that's what I swapped on to the engine and no more readjusting of carburetor every few days. My suggestion is dump the avs2 and go with a better carburetor.
liam
Seatle Washington
Liam
k20
When I first got the truck it had a DeMon 750 and it really made the truck go
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Take off the distributor cap and rotor, make sure the advance weights are free to move and return to their resting spot.
If you adjust the idle speed with the weights slightly advance, when the return to their resting spot the idle speed will be lower. If after driving the truck the weights hang up in an advanced position, the speed will naturally be raised.
You have verified the throttle isn’t sticking?
ASPEC
C2500
What intake manifold are you running?...
liam
Seatle Washington
Liam
k20
Edelbrock preformer eps dual plain intake
ASPEC
C2500
Well, that manifold is a proper fit for the AVS so no worries on wether you have adapter issues or not.
As others have said it sounds like you should focus on initial settings of the carb and verify those. Then search for vacuum leaks and make sure all ignition components are fresh and happily adjusted.
tball67
