Avs2 problems
liam
Seatle Washington
Liam
k20
I have a 1984 chevy k20 with a 350 and an Edelbrock 650cfm avs2 and after installing the avs2 it always seems to unadjusted itself i have had to adjust it 7 different times I dont think that is very normal
ali_c20
Austria
Alexander
C20, K5
First check if your ignition is adjusted right and all it's components are ok. Check for vacuum leaks. No vacuum leaks and ignition spot on - adjust carb.
nbrizjr
