Random spare wires and things
BryanS
Ft Pierce FL
Bryan
Blazer K5
Trying to figure out what these artifacts are.
Bought a 83 k5 someone swapped a 454 into
The only thing electronic on the truck is the radio and it’s broken. There are a few random wires that I’m not useing and would just assume delete
There is also a weird solenoid on the firewall I cannot figure out
Carbon canister with an octopus worth of hoses not hooked to anything and a capped off line into the PS pump.
Any ideas advice very appreciated
I want to clean out anything I don’t need
Jgonick
West Texas
Joel
First image- looks like knock/ detonation sensor
last image-probably plugs in transmission for TTC
maybe the weird solenoid is the low vac switch for transmission TTC
BryanS
Ft Pierce FL
Bryan
Blazer K5
Thank you
Think I need that stuff:)
Best I can tell there are no wires connected to the engine/tranny and the only vacuum lines goto the breaks and hvac
BryanS
Ft Pierce FL
Bryan
Blazer K5
Studying the schematic you shared…thank you
If I’m understanding correctly if I’m not using an esc distributor I don’t need any of that stuff? The distributor in there is manual advance.
Since I got the truck this way and it’s running without any of these wires attached can I assume I can remove them to clean things up a bit?
I would like the ability for the tranny to lock up…can I just rig a solenoid and switch and I can then lock it up manually when I’m on the highway or whatever?
Appreciate you posting the schematics…thank you
Jgonick
West Texas
Joel
Yes. There are several was to modify it- start another post specifically about it and more knowledgeable people than me can probably give you guidance.
Also here is a link where you can download the wiring diagram for your truck
LINK- wiring diagrams
Turbo4whl
Downingtown, PA
Wayne
...and a capped off line into the PS pump.
...and the only vacuum lines go to the brakes and hvac
The power steering pump reservoir was for a truck with a hydraulic brake booster. Both the brake booster and steering box need a return line. The capped off extra return is fine.
BryanS
Ft Pierce FL
Bryan
Blazer K5
Thank you sir
zacharyb
