1lejohn
- May 14, 2012
- texas
- john
- k-1500, 2500 HD
I want to install cats on my 85 truck. It has headers and dual exhaust. The cats will have to be mounted far back in the system. The stock air pump brackets, fittings etc. are long gone. I would like to go back with them, but they are hard to find. I have an electric pump from a car that I think would work. My thought is the pump would only need to run at start up to help the cats fire off. A couple of check valves welded to the pipes and some hose from the electric pump might work. Has anyone tried this set up? Thoughts concerns?
