Redfish
- Nov 6, 2021
- Prairieville, LA
- Andrew
- V1500
If there is, I haven't found it yet!So answered my own question with google I think. There is NOT a Schrader valve on the TBI system for fuel pressure testing. Is this correct?
Also since it’s low pressure, cobbling in a tee is pretty safe.
Although long term and considering you’re unsure of and fiddling with both tanks and pumps it may make sense to just splice in a tee with a Schrader valve on it for a more permanent setup to easily check fuel pressure and disconnect the gauge easily with no leak concerns.
There are aftermarket, adjustable fuel pressure regulators that require an external gauge getting plumbed in. I had no need to do this to mine as it is completely stock except for the exhaust and I figured the stock regulator spring would be fine.
This is a random internet pic, NOT my truck.
