1987 Fresh Air Intake
TurboDog
Laramie, WY
Dwight
V30
Looking at the LMC catalog they only list the air hose connection from the air cleaner to the front grill for trucks up to 1986. My 1987 is the first of the TBI injection engines, anybody know what is different? The LMC 1986 part number is 38-4359.
My truck has a 2" cowl hood...is there a setup to connect the air cleaner to the hood?
I tried a drier vent hose but it is too small, I could probably cram it up inside the adapter but it won't go over the outside like it should.
legopnuematic
Licensed Junk Dealer
MO
Spencer
What does your air cleaner look like?
This is what the TBI 87s I’ve been around look like:
Rickf
Grafton NH
1974, 1954 & a 1937
My old '69 Camaro had a cowl induction hood & air cleaner assembly.
TurboDog
Laramie, WY
Dwight
V30
That 90 deg part next to the air cleaner must be what I'm looking for. I have the short acordian piece,and thought that went on the air cleaner. Thanks for the pic I now see it goes on the front radiator support.
Do you know where I can buy that other piece?
gmbellew
Kansas city
glen
suburban 1500
The first 90deg bend is integral to the air cleaner assembly. The second bend in the accordion is also one piece. Check Ebay, I bet you can find what you need there if you don't have a nearby yard to check.
TurboDog
Laramie, WY
Dwight
V30
Ebay was a bust...could only find a few very high priced ones off a G10 van...not the same.
TurboDog
Laramie, WY
Dwight
V30
This is my air cleaner housing and the accordion piece that came with this truck may not be right. It is only about a foot long and either fits onto the round adapter on the radiator support or the oval entry of the air cleaner housing.
legopnuematic
MO
Spencer
Someone here I think was 3d printing an adapter for those air cleaners.
legopnuematic
MO
Spencer
carnutjw
Evansville, IN, USA
R20 Suburban
My air cleaner is a '87 big block version and I suspect the opening is different from the 350 version, but I can take some measurements this evening to compare.
Geoduck
PNW
Thank you Dwight! I've been looking for this hose.+ Ordered one for my 1985.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Will try to remember to look when I get home, but may have an 87 hose still from a truck that was 5.3 swapped.
OllieJay87
Thomaston Ga
Andrew
V10 Scottsdale
I was having a problem finding one for my 87 v10. I ended up getting one at a junkyard. It was pretty dry rotted in places. I ended up flexsealing it and extending the end with a thin wall pvc pipe to attach to grill piece, on account of the end lip breaking off. I will paint pvc at some point.
mtbadbob
Montana
Bob
V20
I believe the TBI snorkel tubes are a bit longer because the air cleaner housing locks down onto the TB in a certain position, where the carburated versions were canted more toward the front. On my '87, I tried a snorkel from a different year, and it was a little too short to connect to the core support duct outlet. I ended up finding a correct one on Ebay, but it was NOT cheap! I still have the other tube if your interested, but it isn't correct for the '87.
unimogguy
