Redfish
- Nov 6, 2021
- Prairieville, LA
- Andrew
- V1500
I truly think @bucket is right about the pump.
I will add that since you mentioned the PO installed new pumps the two things I would be focused on would be:
1. What brand of pump did he install vs. what you are installing.
2. The ground wire connection which I know you are already concerned about and @Strick has been good enough to provide pics of.
