ChuckN
Bellinham, WA
Chad
Try changing the power valve. Numerically higher I believe, that might just be on a Holley though. The edelbrocks seem to be love or hate. I'm not too fond of em lol
Yeah, no power valve on an Edelbrock that I’m aware of.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
They’re all like that on all squarebodies.
Did you see Soundmounds pic? His tanks look like the senders are tucked under the cab...am I wrong? I assume they were all like mine until I saw the pic he posted in this thread with the bed off.
Strick
Dunn, NC
Harold
C20 Crew
What I love about Carter/Edelbrock carbs: bolt on & drive them‐where ever you want. What I hate: spinning over of the engine after sitting for a spell. I have 4 Edelbrock Squares if you want to know.
Cleaned the bed out and Junior took his quad out to his girlfriends house to ride.
Now the transmission pops out of 3rd gear.
Choices have to be made soon.
Fix the trans I don't like with snap rings and shift forks.
Or start the conversion to 4L80 I have.
Hmmmm....
That's definitely a tough decision.
You know, the aluminum top type shifter makes for a much nicer driving experience. And you would still have the stupid simple manual transmission. Just a thought.
ChuckN
Bellinham, WA
Chad
It’s true- the vents seem to let a lot of gas evaporation.
Soundmound
North Central Washington
Dave
Scottsdale
She's breathing now. 3" from the Y back through a Magnaflow 12259 and dumps out the stock location. Literally all I got to hear it before I had to run to work. Don't even know if I'm happy with the sound yet, but it was cheap, looks good and serves the purpose. Old vs. New
ChuckN
Bellinham, WA
Chad
Sounds nice and mellow.
Depends on which size tanks you have. 2 of my 3 trucks pulling the bed does you no good for tank access.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
So I got under and found that the catalytic converter is directly in front of the drivers side front tank strap. The rear strap seems to be easily accesible Please see first 3 pics:
Yeppers, I had the same problem.
So, I assume you took down the poly cover.
I loosed back strap some, so it's not poking through the frame. Removed all 8 bracket bolts. I supported tank with a trans jack whatever will fit...got the front bracket away from the frame enough to get a 18mm wrench on it from below, to loosen some. Problem for me was that front strap bolt got hung up over frame. Little pry bar and shimmy shimmy. You'll get there.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
The front drivers side sits above the frame, thus no hole (in frame). I can't get to (tried a lot) because the shield for the cat is there. I used pivot etc extensions bla bla.
Removing the poly shield did give more room to move the tank, but not enough and strap thread hung up over frame. Loosened with wrench and pry bar to koax tank came down.
Exactly to your statement. I may use a sacrificial nut to not damage the new one I'll leave on, even run a die if needed. Seems PITA. Passenger side should be better.
Driver Tank up, ran it for it's 1st 10-15 minutes. Front bypass fitting started leaking a drip. Daughter's like "something getting on the winshield".Shut down and started tightening. Yikes. Engine definitely got up to 210°. It was so exciting to run the 1st time.
Ajax19
Socal
Ajax
Videos are the dash cam footage from the other day and was doing some 4x4 launches just messing around truck needs lockers got a one tire fire up front new dash cam/GPS (also android auto)is in and it's 2.5k front 1080rear camera I used Velcro on the dashboard worked out pretty good love the functions of the new screen can even screen mirror watch movies, YouTube etc and only $100! Working with Bluetooth stereo and phone first pic is rear cam at night with all my lights on headache rack and reverse 2nd pic is split screen GPS and rear cam
Redfish
Prairieville, LA
Andrew
V1500
Take a look at the pic posted by @Strick on the previous page. That truck is a long bed but the connections are definitely under the bed on that truck. I believe it is an '87 also.
Redfish
Prairieville, LA
Andrew
V1500
How perfect does it need to be? Would you actually know it wasn't right if you did not have that new monitoring system in place?
I know that we all want our trucks to run the best that they can but sometimes close enough is...well, close enough. Of course if you can feel it stumbling or bogging or whatever it is doing then you would absolutely need to fix it. I would guess that there used to be a bunch of carbureted vehicles that were not Perfect at all throttle openings or RPM. There are still quite a few out there actually, I can smell them at pretty much every car show I attend.
bubbalicious24
