The squeaking is getting on my last nerves
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
What’s up guys!!!
…so recently I lowered my front end drop spindles, drop springs, drop shocks and I’ve also changed out all of my front end parts, bushings, control arms, ball joints, bump stops you name it…but now I have this squeaking sounds on the right and left as the truck drives. I’ve lubed every grease fitting possible and it’s still squeaking…. any remedies to this situation ????
Do you have a front sway bar?
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
yes i have a sway bar
Normmus
Saskatchewan
Norm
Did you use urethane bushings or rubber bushings? I've heard that the urethane ones can be loud if not sufficiently greased on installation.
It could be that the bushings are not happy in their new position at a lower ride height. Or if they are new, poly bushings tend to squeak without grease.
Was gonna say, I hope you didn't use all poly bushings...
Camar068
10 yrs Air Force
yeh I hate that they make them red so they look cool and all lol. Needless to say, that's what's on my truck. Live n learn.
Helped a buddy in college do all the bushings in his foxbody in poly. After 6 months, could here that MF'r coming from across town. Never again have I touched a poly bushing
Scott91370
Burleson, Tx
Scott
Sierra1500
Did you tighten everything after the truck was down on the ground with the full weight of the truck?
Also, grease joints and bushings.
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Will do
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Waz up Guys. The fix to my squeaking lower control arms was faulty grease fittings not taking in the grease. Cost me $7 plus my mechanic charged me $35/ replaced all fitting and greased everything. Im quiet as a mouse pissing
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I had a 2003 Ranger redone and they used the red poly bushings. Rides good, steering is nice and tight with perfectly even tire wear, but it sounds like a collection of "by the hour" hotel rooms coming down the street. Had a couple other shops confirm that there is nothing technically wrong or unsafe with it, it just sounds terrible. Unfortunately only way to quiet it down would be to pull it all apart and start over which is more $$$ than I want to spend if its not actually harming anything.
I used poly bushings for my cab mounts, and greased them lightly as was suggested. They still squeaked when first installed, but settled in and quieted down after about a month of wear in.
bryanedge117
