Engine start issues
Weasel74
North Carolina
Jon
Chevy Cheyenne C-10
I have a ‘74 Cheyenne with a 350, th350, rebuilt Q-jet carb & new gas filter, new gas tank, sender, and hose lines, new fuel pump, new coil, plugs, points, rotor and condenser. The engine may crank for a few seconds and die off. The dwell is correct and the timing was not moved when it was running. I have set the idle mixture screws at 2 turns out. I have checked plug wire sequence and all vacuum lines are connected.
Any suggestions or help is greatly appreciated! Weasel74
Truck82
Alderton
Christopher
The starter dies off and won’t crank the engine? If that’s the case it’s most likely in the electrical.
When you say crank and die off,do mean the engine starts and runs briefly?
Make sure you have 12 volts to the distributor in start and run positions. The rod connecting the key mechanism to the electrical switch make be flaky, and the switch is not providing power to the distributor in both positions.
I would also try a cold start by pouring a few ounces of gas into the primary side of the carburetor, and then reinstalling the air cleaner (in case of backfire). If it then starts and runs for a short time, it’s a fuel delivery problem. Time to start checking the Quadrajet fuel filter, float level, needle, etc.
Weasel74
North Carolina
Jon
Chevy Cheyenne C-10
No -the starter is Ok. It cranks the engine fine but it dies after a few seconds-crazy!
Weasel74
North Carolina
Jon
Chevy Cheyenne C-10
What is the best way to check if 12 volts is going to Distributor in start and run positions. I’m kinda a rookie in this area! Thanks
If it is starting its getting 12 volts at cranking,if it starts and continues to run a few seconds after you release the key it's still getting 12 volts.If it starts and dies it is most likely a fuel related problem,try wedging the choke plate open 1/4 inch or so,a wooden clothes pin works good, pour a tablespoon of fuel down each of the primary barrels try to start the truck and keep it running with your foot,try 2 or 3 times. Does it start and run then? Keep some dry rags handy,sometimes they'll back fire and light off any fuel you've dribbled on the top of the carb. NBD smash the rags down it will snuff right out. Doing just this will answer several questions. Let us know the results.
I gotta go,busy busy today look at the pic below the hole I'm pointing at if you pull off and leave off for now the big hose directly ahead and below that,then fill the carbureator through this hole,use a mustard bottle or a dish soap bottle .About an 1/8 th of a cup if you fill it too much fuel will dribble out where you pulled that hose,i just fill them till they dribble. If it starts,runs,revs feels normal for about 10 or 15 seconds. I'd look at fuel delivery. Issue's. I'll post more later.
Weasel74
North Carolina
Jon
Chevy Cheyenne C-10
I adjusted choke, added some gas and it finally started OK. I set dwell and timing after I got engine to idle without cutting off. Thanks for all suggestions!
Cyrillious
Toronto
Cyril
K10 Suburban
Yes -for a few seconds and stops
Check and make sure you do not have a vacuum line popped off. I've had that happen and it has done the same thing to me.
Dezzracer
Las Vegas
K10 Scottsdale
If you have saddle tanks with switch have you tried both tanks? Check your fuel lines for kinks all the way back to tank (s).
anthonycorbella86
