Huck's daily - 2005 Z71 crewcab
Got on the front diff after work today. Unfortunately I forgot to take pictures a lot of the time. I managed to get the cir clip off the pass side axle and get it out of the extension housing so I could replace that axle seal.
Got the new ring gear transferred onto the original carrier
Threw the pinion in with the setup bearings (they’re the same as the rear axle). Then pressed on the carrier bearings, put the side adjusters in and carrier races in. Dropped the carrier in.
Then put the case halves back together so I could get a backlash measurement
Got creative with the setup for measuring lol
That’s a HUGE Chrysler battery out of the boss’ 2021 Durango lol
Had to take it back apart a couple times. It’s such a ratio change, leaving the side adjusters where they were at disassembly wasn’t even close to right. So I ended up just backing the drivers side all the way out to get the ring gear close to the pinion and then sneak back up on it. With the adjuster from the outside.
First measurement got me at .055-.058-ish. This is a very difficult thing to measure/feel so I was working with ranges. Also had to keep in mind I had to divide by 2, so that put me at .0275-.029.
Adjusted the side adjusters some more and got down to .041-.043. Kept sneaking up on it, basically a tooth at a time on the adjusters
Finally, got it to .017-.019. Spec is .006-.010. So that puts me right in the meat of the range, .0085-.0095. Score!
All the maths again
So then I threw some paint on and checked the pattern. Unless Spencer or someone sees anything I missed, I’d say that’s good enough for the girls we date. Especially for the front axle that only sees occasional use
Good stuff Zach! You know your stuff! This guy has a good tear down video for this axle if anybody wants to watch.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Looks decent from over here. I don’t envy you having to play with that clamshell differential contraption :D
I was hoping I might be able to completely finish up the front diff and have it ready to go back in the truck last night, but of course that didn't happen. Lost 45min brainstorming with a buddy on the phone about fuel systems for 2 trucks he's building. And I decided to use the heat the bearing/freeze the pinion trick but didn't think about it early enough in the night so I lost about 1.5hrs on that waiting for it to heat up and then cool back down (I ate dinner while I waited) instead of being able to multitask.
But I did make some progress. Got the the case split and pulled the carrier back out, cleaned the marking compound off the gears, replaced the ring gear bolts with the new ones (had a brain fart and had reused the old ones, thankfully I had not locktited them), locktited and torqued them down. Got the inner pinion bearing on (plopped right on, heated to ~250 for 30min with the pinion in the freezer for that 30min), threw the crush sleeve and new outer pinion bearing on. Pinion seal and yoke on and started tightening it down.
I learned that the front diff is a little different than the rear in that you start getting into the crush sleeve before the for and aft movement in the pinion is taken up, like quite a bit before. So that was frustrating. Set the case half on some cardboard on the floor with that big battery on top and my deadblow underneath for stability. Started out with my 1/2" breaker bar, ended up spreading the ears on that once I started to get into the crush sleeve. I grabbed the impact out of frustration and was sitting there thinking about it when I remembered the boss has a 3/4" kit, I grabbed that breaker bar and 32mm socket and a jack handle for a cheater pipe. That worked like a charm, guess I'm picking up a few 3/4" tools now.
FINALLY! Got to where I need to be. I literally laid on the floor for a few minutes after that, that's a workout lol
It took nearly 1.5hrs sneaking up on it to finally get the rotational torque spec. I was just turning it 1/4-3/8" each time and then recheck. Landed at 18in/lbs, spec is 14-19. Perfect! Double checked on the table with an extra hammer supporting the other ear.
This is what I think of doing crush sleeves on an IFS. The rear is much easier
Well...I have bad news. Worked my ass off getting the front diff back together and in the truck, going over everything a second and third time before taking the truck out on it's maiden voyage around the lot at work. And it was a fail :doublepuke::oops::banghead::banghead::banghead: Got noise coming from both axles.
The rear isn't so bad, it's a very mild noise above 20-25mph. It's a rotational sound, like I can hear each tooth on the pinion meshing with the ring gear. The front is fine in 4lo going slow, but put it in 4hi and above 10-15mph it gets a horrible bearing roar. Only in 4hi at speed, can't hear anything in 2wd from the front.
Bad part is, I'm not really educated enough to know where to go from here. I didn't even put half a mile on everything, just back and forth a couple times in our back lot and one lap around the building (there's gravel on one end, so I put it in 4wd to make sure nothing was binding before I tried 4wd in a straight line in the parking lot). Checked both axles with a temp gun when I was done, they only got to 60*, so hopefully things can just be adjusted without replacing anything but maybe the crush sleeves.
I'm wondering on the front if I have it too tight, with everything loaded in the carrier, my rotational torque/drag was like 24-26in lbs. It was in the .008 range with just the pinion. That might explain the bearing roar.
The rear, I guess my pinion depth is a little wrong. Either way, I'm parking it again until I can read up/get some advice from more experienced people. I'm so defeated right now, very tempted to just get it towed to a local shop in town and let them go back through everything.
Yeah, that’s the plan, at least right now. I ordered a book on setting up 10 and 12 bolts that should be here tomorrow, gonna read that and see if it’s got any “if you end up with this noise, check this” tips and tricks
legopnuematic
MO
Spencer
Dang man, I really hate to hear that.
The good news is, since you only went a very short distance, no damage should have been done to the gearsets.
This might be worth a read here: https://www.yukongear.com/blogs/dia...6yk71RraNwQ2qVtuVP8HvrJZexkjTF2SuHQZo0RqC6BfH
Feel free to reach out if you wish, I’m happy to do what I can to help make this right.
I certainly appreciate all the help you've already given me! I'll keep ya posted on what I find. I doubt I hurt anything unless something spun/moved on me with load on it, that's why I specifically didn't go far or even drive much in our lot.
Thanks for that link, I had not found that on their site
I also picked up this book to read, should be here today
Rustisbest
Tennessee
6.1762844 liters
Something that helped me if you decide to tear back in to it and check the pattern was to really thin the marking compound out. Spin the pinion with socket adapter on a cordless drill in forwards and reverse as fast as it'll go. Can add a little resistance with a prybar or your hand with a leather glove if you're careful.
On the rear did you add shims to each side of the carrier after checking backlash? Or did you check it with preload?
On the front for carrier preload I'm thinking I went a 2 extra notches on each adjuster after getting it back together. It's been a while though and I don't remember exactly. I remember making a tool to tighten them though.
kobedemello
