Vendors
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Just google for a parts list. Theres a reference part of this forum. And you can buy/download service manuals which break it down pretty good.
Oh. So you meant "which do you mean?" as opposed to "what do you mean?".
No. I said what I meant to say. Such as "What do you mean you want a parts list breakdown for your entire truck?" :flipthebird:
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
An LMC catalog Is a pretty good parts breakdown IMHO.
mlsceo
Kingsburg California
Manuel
And I meant "which" as in is there a specific list you need. Body, suspension, etc. :flipthebird:
Jhaase
Wisconsin, USA
John H
C1500
Looking to buy a spot weld cutter, is 5/16'' OK, or should it be 3/8''. I see the Blair cutter is USA made. Anyone recommend a different brand?
Thank You
Thank You
I've used the Blair spot weld cutters for 26 or so years now. I won't use anything else.
However, I don't use them how they are intended. Rather than using a center punch and relying on the spring loaded center pin to keep the cutter centered, I simply pre-drill an 1/8" pilot hole.
Jhaase
Wisconsin, USA
John H
C1500
I have not used a spot weld cutter before, will the 5/16'' be large enough for the normal square body welds, or should I use a 3/8"??
For any panel that you are removing and not reusing, 3/8" will give you more fudge room on accurately drilling the whole weld. If you are trying to remove a panel to install again, or removing a panel by drilling from the backside, a smaller hole is desirable for a better quality and smaller plug weld upon installation.
82jimmy
