Chris64
- Sep 16, 2024
- San Diego
- Chris
- K20
Finally took it for another drive!
So Second drive - way better than the first!
I actually made it to the gas station and got gas.
AND new problem list.
* I was thinking my temp gauge wasn't working - It eventually did start working when I turned the car off. I need to inspect my thermostat, it may not even be there.
* Speedometer isn't working. The cable for it plugs into the transfer and seems ok, but it's a little leaky.
* Since I've had the motor running, the transfer case has been leaking a little (small puddle).
* Braking feels pretty weak. I was hoping the discs would clean up with a little use but they still feel pretty rough. But it does stop.
* I'm not sure if it ever shifted into 3rd. (Turbo 350 trans) The engine was getting a little wound out. I can't say how fast since I had no speedo.
* oh yeah, when I went to pump gas it would just fill up the hose and then click off. When I'd take the nozzle out it would spit a lot of it back out. I'm thinking the breather tube may be clogged or maybe has a broken check valve. If I held the nozzle cover with my hand I could fill it fine (without sealing the filler opening).
Anyway, I'm all ears if any of this sounds familiar.
How hard is it to rebuild an NP203 transfer case?
I think I'd like to have a tach and maybe put it where the brake warning light is.
New projects!
New projects!
