bluex
- May 9, 2013
- Spartanburg SC
- Paul
- C15
Ah interesting.
I was wondering.
I just recently replaced the NV4500 in my 98 with one from a 95. I figured one for one swap, be easy. Nope.
95 is an external slave, 98 is an internal slave cylinder. Required me to get a new flywheel, clutch, and pressure plate.
Bellhousings don't swap either, different bolt pattern and center bore. What a pain.
Im gun shy now, lol
This also should have only required a pressure plate change to the older 95 an down style. The bellhousing is different because of the different bearing retainer styles between clutch fork an internal slave.
