- Feb 24, 2020
- Auburn, Georgia
- Zach
- Sierra 1500
Oh crap, you're right. I forgot about using the races. Oops
It's not that hard,really.It's a little intimidating,first one but really not hard. If you ever want to try,there are plenty of us on here that can get you through it without trouble.Damn fine work sir.
All the voodoo required has me using a diff guy and paying his prices.
Oooo, thanks for the tip on the lube, gonna pick some of that up. I also definitely need to get some more emory cloth, can't find mine and there were a couple small high spots on that pinion as the bearing went down. Nothing to cause an issue but made a ghost mark.With your press woes, some extreme pressure grease goes a long way on making press fits smooth, mitigates galling, etc. something like this:
Doesn’t hurt if things feel really tight to run a little Emory cloth on the journals, just enough to make sure there are no dingleberries that might give trouble.
Being a machinist, I have the luxury of being able to make sleeves to be able to press pinion bearings with the pinion facing up. I like that way as I know I’m not hitting the cage or anything, and am pressing on the inner race. Also be careful with stacking those press plates on those pieces of channel, I’d be worried about having something slip with that setup.
Nice work and good luck on the front axle!
Thanks! This is my first time. I've always paid someone else to do them. But needing to do 2 axles at one time, I decided to spend half the labor money to get the special tools and give it a go. It's not bad, just tedious learning as I'm going. It's taken 3 times as long as it would someone that knows what they're doing, but thankfully I'm not in a hurryDamn fine work sir.
Next one won't take 1/2 as long. Wish I'd known you were doing this,there are work arounds for most of the tools. But now you own tools,saved money and have a new skill. Even of you are an arrogant whatever that guy called you.Thanks! This is my first time. I've always paid someone else to do them. But needing to do 2 axles at one time, I decided to spend half the labor money to get the special tools and give it a go. It's not bad, just tedious learning as I'm going. It's taken 3 times as long as it would someone that knows what they're doing, but thankfully I'm not in a hurry
If you want more practice after all this.. I have two more axles you can try and beat your lap time with.Thanks! This is my first time. I've always paid someone else to do them. But needing to do 2 axles at one time, I decided to spend half the labor money to get the special tools and give it a go. It's not bad, just tedious learning as I'm going. It's taken 3 times as long as it would someone that knows what they're doing, but thankfully I'm not in a hurry
Yep, I'm always game to find reasons for buying new tools lol. I actually already have 2 more 10-bolts lined up to do. My blue truck I'm going from 3.90s to 4.30s and then my tuner buddy wants to change his cammed 5.3/4L80 '93 OBS from 3.42 to 4.10.Next one won't take 1/2 as long. Wish I'd known you were doing this,there are work around for most of the tools. But now you own tools,saved money and have a new skill. Even of you are an arrogant whatever that guy called.
