Progress on the bull bar I used 1/4"×6" plate 2ft Long each some scrap angle iron for the mounts and some 2 1/2" scrap pipe and some tabs for the lights getting dark so will continue on tomorrow
@EvilGenius this subject got moved to here. I just wanted to tag you in it so you could follow along.
mtbadbob
Montana
Bob
V20
I tackled the intake gasket replacement on Saturday. 8 hours later...I was headed back home. I didn't get to time it with a light, just by ear as my dogs & I were both getting hungry! By the time I got home, my idle was high, and it was lacking power, so I feared I had a bad air leak because I over-torqued my intake bolts a bit. Visually checked for fluid leaks, but everything was dry & normal looking. Sunday, I headed back to my buddy's shop to throw the light on it, and realized my high-idle was due to my cruise linkage pulling the throttle open. Got it timed, topped it off with more coolant, now it's idling like a champ and running great! Also found out that my wiper motor plug had somehow came unplugged, hence why my new wiper/cruise switch wasn't working correctly. i plugged it back in and VOILA! All wiper functions now work perfectly again! I did not know that they could even work without that plugged in, but it must be a secondary plug for the intermittent module?? Now, I still have to troubleshoot my brake switch to see if that's why my cruise isn't working. We got about 8-10" of new snow, and I drove the '87 today and it ran like a top and got around pretty good. It feels good driving these old trucks with all their primitive features & functions like lock-in hubs & a transfer case lever. She shifts in & out of 4WD on the fly greatly!
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Well, once again I was wrong. It was pure coincidence that the noise went away during my troubleshooting. The fan clutch was NOT the noise. It was the alternator. That alternator has less than 5K miles on it and I paid good money for the AC Delco part. I remember when I installed it that it would growl with the belt as tight as I thought it should be. I backed off the belt tension and it seems to be fine. I am not happy with it but I will drive it a bit and see.
Not happy with it or me. At least I have a new fan clutch...whether I need it or not.
Was the fan hitting/ scraping the housing? I had that recently happen on a newer unit.
ChuckN
Bellinham, WA
Chad
Just got back from the muffler shop- they welded the O2 sensor bung in the driver side, then the offered to put one in the passenger side as well so I told them to have at it.
Felt so good to have it out on the road that I drove her around all afternoon to do errands.
Redfish
Prairieville, LA
Andrew
V1500
Nope, the bearing is just raising hell and making a lot of noise when the belt tension is high. I cannot see the pulley getting out of alignment but the noise is surely there.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Jealous!!
My Uncle in law has a computer plug in do-hickey, OBD2(I think) and we are going to see if it and the dash tells us something more specific about my current sideline.
ChuckN
Bellinham, WA
Chad
Jealous!!
Hope you get it sorted soon! It’s hard to sleep when our trucks aren’t running right. Seriously. Or at least I don’t sleep well.
I’m looking forward to having an AFR gauge so I can dial in the carb. For all the “Meh” that the Edelbrock AVS gets, it works really well. Starts easy, mild mannered in traffic even with the lopey cam, just doesn’t like sudden size 10 1/2 foot slammed to the floor. Once it catches (less than a half second) it takes off like a shot. Hope to figure out if it’s getting too much or too little dinosaur juice in sudden WOT situations.
Jealous!!
Just FYI, your truck is not OB2, it's OBD1. You have to use the paper clip method and count the blinks in the dash to get the codes
Carb'ed Vortec 350
On my 91 Cherokee I just turn the key to on-off-on-off-on without starting it and count the blinks. 55 to start, then the codes blink, then 55 to end.
Ajax19
Socal
Ajax
Had to switch gears from the bull bar to getting the gooseneck hitch on the 83 some pretty bad wildfires near me and my buddy asked if I could get the hitch installed in case they need me to get them out of the dangerzone since he no longer has a truck starting by pulling the deck boards and since this hitch was designed for a 2020+ Silverado gonna need to shorten the cross member 3inches and notch the receiver a bit but it should work out real nice and hide under the deck of the flatbed it's a b&w turnover for anyone wondering should be wrapped up by tomorrow just need to make a few cuts and drill some holes
ChuckN
Bellinham, WA
Chad
Had to switch gears from the bull bar to getting the gooseneck hitch on the 83 some pretty bad wildfires near me and my buddy asked if I could get the hitch installed in case they need me to get them out of the dangerzone since he no longer has a truck starting by pulling the deck boards and since this hitch was designed for a 2020+ Silverado gonna need to soften the cross member 3inches and notch the receiver a bit but it should work out real nice and hide under the deck of the flatbed it's a b&w turnover for anyone wondering should be wrapped up by tomorrow just need to make a few cuts and drill some holes
Be safe out there!
ChuckN
Bellinham, WA
Chad
AFR gauge is a go. Took it for a drive, way too rich at idle in gear. Leaned it out, raised the idle back up a bit, much improved.
I’d gone to the silver step up springs quite a while back thinking it was running lean but I ended up putting the orange springs back in, and off idle is in the 13s though I’m finding that I need to give the gauge a little bit since the readings tend to lag a bit to find their nadir- I might have to lean out the jets a bit but now is much better.
Ajax19
Socal
Ajax
Gooseneck progress cut the cross member shorter by 3in and relocated holes and you can see picture 2 it will sit flush under the bed(I think I have to get the 1" taller ball) upgrading all bolts to 5/8" grade 8
picture 4 I need to run and get some 1/4" 3in angle and re make the bracket(tried using some scrap tube but not happy with it to thin and didn't make it long enough to fit at least 2 5/8" bolts the 1/4" plate with the X I'm upgrading hardware from 1/2" to 5/8" and there is 6 of those plates tied to the frame(plus rear end of flatbed/hitch/frame/bumper all welded together) I also have some plans to tie in the rear cross member in better yall just have to wait and see
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Seems like a lot of screen shots of photos getting posted lately...
bubbalicious24
