WFarm
Central Virginia
K5 Blazer
Several smaller jobs today. Replaced the cowl screen after spraying the inside of the cowl with WD40 and wiping it down. Cowl was very clean, no rust. Then replaced the tailgate glass guides as the old ones were chipped and broken. Replaced the firewall power distribution block and PCV valve and called it a day.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
I don't know what Ted's exact "wants" are, but it needs to be good enough to pass a PA safety inspection so he can drive it again, lol.
@78C10BigTen
well lucky for him i enjoy both Square Body body work and I'm a licensed PA state inspection mechanic
Curious about the WD wipe down inside the cowl. Just to keep stuff from sticking in there?
WFarm
Central Virginia
K5 Blazer
Helps prevent corrosion.
WD-40 was developed by the Rocket Chemical Company under contract to the DOD to protect the thin aluminum outer shells of nuclear warheads from corrosion as they stood in their silos. Water Displacement Formula # 40 (hence WD40) was the ticket. Eventually the DOD allowed the product to be offered commercially.
I actually knew that but had forgotten. Good point! I know alot of people also use it on undercarriages/wheelwells/backhoe buckets/etc cuz it helps keep stuff from sticking as bad
Redfish
Prairieville, LA
Andrew
V1500
Well, once again I was wrong. It was pure coincidence that the noise went away during my troubleshooting. The fan clutch was NOT the noise. It was the alternator. That alternator has less than 5K miles on it and I paid good money for the AC Delco part. I remember when I installed it that it would growl with the belt as tight as I thought it should be. I backed off the belt tension and it seems to be fine. I am not happy with it but I will drive it a bit and see.
Not happy with it or me. At least I have a new fan clutch...whether I need it or not.
ChuckN
Bellinham, WA
Chad
Got out to the garage and routed the O2 sensor cable into the cab. Then, since someone before me chopped the bezel to bits for a radio that no longer exists, I formed a piece of plastic and mounted the AFR gauge in its place. Tomorrow the bung gets welded onto the exhaust.
Through the mess of wires, I sorted out the various speaker wires and isolated the power for the radio and ground that I’ll repurpose for the gauge, and put a wimpier 5 amp fuse in the radio fuse per their recommendation.
Ajax19
Socal
Ajax
Previously Posted this on the wrong thread... so I'm making a bull bar for the 75 and scored some hella lights for the trucks and a 5th wheel for the 83
Ajax19
Socal
Ajax
Progress on the bull bar I used 1/4"×6" plate 2ft Long each some scrap angle iron for the mounts and some 2 1/2" scrap pipe and some tabs for the lights getting dark so will continue on tomorrow
Ajax19
Socal
Ajax
These are the ones I used for the design all slightly different but the black bull bar is close to the look I'm going for
That black one looks very close to the one on my '88. Still slightly different though. There must have been countless manufacturers.
Truck82
Alderton
Christopher
Look at those wheels on the k5! :roflbow:
That suburban looks mean though. I like it
sparks22
