Body swap on a c10 1981 to a 1985 k1500
joseph26
bowdle
Joseph
I was wondering if I can do a a cab swap with a 1985 k1500 to a 81 c10 cab
Yes
joseph26
bowdle
Joseph
Ok are the body mounts the same
Uberbeans
Florida
Charles
K-5
Yes I did a swap before and the years it really changes is between 80 to 81. I think your swap will work!
Npanek
Parsons Kansas
Nick
C15
Center hump in k cab is taller than one in c cab. Otherwise everything else is a direct bolt.
Keith Seymore
Motor City
Keith Seymore
4.3L
This.
Column shifted 2wd (ie, auto trans, or three on the tree) = low hump
Manual shifted 2wd (ie, M20 with creeper, or MY6 overdrive) and 4wd are all high hump.
There might still be enough clearance to go from high hump to low hump because the factory put enough margin in there to account for worst case user over the life of the vehicle, smashed body mounts, twist, etc.
K
pr1978
