TDoc
- Jun 8, 2021
- Flagstaff, Arizona
- Terrell
- K10, K5
Hi all,
I just picked up a new to me 1986 K5 blazer. Glovebox build sheet says it has the LE9 5.0 Liter V8 Gas GM. It supposedly has 190k on it and runs really well except for some blue smoke unitl it warms up. I have the 700R4 4 speed auto and thankfully GT4 rear axle 3.73 and NP 208 transfer case.
1981-1986 LE9 with 4 Barrel Carb
Max Brake Horsepower: 165@ 4000 rpm
Max Torque: 250 @ 2000 rpm
Stroke: 3.48
Bore: 3.736
Compression: 9.5
Firing Order: 18436572
Truck runs good and looks like it has the 4bbl quadrajet. Everything is stock, air pump, vacuum lines everywhere, stock exhaust. Catalatic converter was removed at some point.
I live at 7k ft elevation and could really tell the performance drop when driving it home from 5k ft elevation.
1. Will dual 2.25 exhaust help or is that too much exhaust for the 305? Thinking about just putting dual 2.25 and leaving the stock manifolds. https://www.summitracing.com/parts/wlk-89005
1a. Long tube Headers + dual exhaust? https://www.summitracing.com/parts/sum-g9006
2. The LE9 has Electronic Spark Control, any upgrades for that to make the timing advance come in earlier? Can I just set total timing at 32 degrees like a normal HEI with vaccum advance unhooked and ESC left alone?
3. I have the big factory air cleaner with factory cold air intake. Leave that alone or switch to the "hot rod" standard open element that takes in air from the engine bay? Warmer air but no restriction from the stock setup.
4. I can tune an edlebrock carb but haven't messed with the quadrajet. Its probably running rich but I may try putting smaller primary jets in it. If I do the exhaust that should lean it out a little, correct?
5. We don't have emissions testing where I live, I was going to unhook the air pump and delete a bunch of the vacuum lines related to emissions. Do I need to plug the air lines into the manifolds or just leave them as is with no air pump?
5a. There is a vacuum operated valve on the exhaust down pipe, guessing that is for faster cold start warmup.
Thanks for the help!
Stroke: 3.48
Bore: 3.736
Compression: 9.5
