Have you checked your ground?
Everytime I see this I want to scream! Grounds are not rocket science or difficult, if your component doesn't come on and you verified you have 12 volts to it,provide a ground from the component to a good ground. Did it come on,you just verified the ground is your problem. Component works but not like it should ground 1 lead of your meter to a good ground,hook the other end to where your component grounds,read your meter is it reading more than .5 volt? You've got a sketchy ground clean it. You can do the same test on the positive side 1 meter lead to good positive, 1 meter lead to the component. The component does have to powered on and running to check volt drop on either lead. There's going to be arguments about how much drop is acceptable,rule of thumb is .1 volt per connection,if you have less than 1/2 volt drop,move on its not your problem. In the car I have a cigarette lighter plug with nothing attached,I can plug it in the cigarette lighter,now I have a ground wire and a hot wire,cigarette lighter is high draw circuit,sufficient for anything I've had to test. Busy will come back later to edit and punctuate. Have a great day. Components grounded to another component like alternator,check alternator body to block for volt drop,distributor body to block etc.
Keith Seymore
Motor City
Keith Seymore
4.3L
I used to ask questions of the electrical Vehicle System Engineer all the time. I had him on speed dial from the back barn to his pager.
"Hey Jerry" I'd say. "I've got this problem -
"Bad ground" he'd say.
"You didn't even let me finish!"
"I know. Start by checking the grounds".
Usually he was right.
K
75BEASTK20
B.C. CANADA
Cal
A faulty ground was my problem on my dual tank setup.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I am a field Service Engineer for a major auto manufacturer. I see so many times where a tech has replaced all kinds of parts. I get there and in 15 minutes we have found the wiring issue. Voltage drop testing.
Start with the basics, fuses, grounds, etc.
They are easy to check. And they are simple. Sadly sometimes they are hard to find, but the FSM usually has each one pointed out in a photo.
Who's a dirty ground...lol...
dirty grounds refer to high amperage grounds at the same location as low amperage ones. The TBIs early on had an issue with this, the engine ground either studed to the same spot as the PCM grounds iirc on the water neck
some components could end up badly grounded when the ground straps would not be on, because insulating materials between components (plastics)
Dleslie212
Phoenix
Dustin
5.7L 350
I finished a re-wire of my 77 a few months back. One of the things I did was to completely create new grounding points with threaded studs and nuts/washers
1 - underneath bed between fuel tanks
1 - at rear fram
1 - at firewall, next to fuse block
1 - at driver side fender
1 - at driver side frame, next to block
1 - at passenger side frame, next to block
All of these ground points are daisy chained together using long battery cables with eyelets, bolted to the studs. Each stud can act as a grounding point. When I have something I need to ground, it just goes to the nearest stud and connected with another eyelet
1 - at rear fram
The GM plated studs? DO NOT DAISY CHAIN ALL GROUNDs .you can daisy chain some grounds. The daisy chaining will create what i talked about above. The bed, rear frame can chain. The firewall can chain to the other firewall, you can probably do the fender to. You should do the frame to the body , only one is needed but better than the OEM one lol. Then the the frame to engine is wise if you dont want to have such a large cable to the battery over the top of the engine. create a path to the frame then to the battery. but if you dont mind the battery to bracket, its a good setup. wBlock tob attery is better
Dleslie212
Phoenix
Dustin
5.7L 350
Good info - thank you
Seibelc1077
