Little help please
84c10454
Erik
I need some help figuring out what I should do I bought a 1984 c10 after graduating high school i bought a 454 bb it came with an electric water pump and I was wondering if I should run electric water pump or go mechanical and what kind of radiator and electric fans would I need I'm new at this not really sure what I need i bought a kwik wire harness 22 circuit any help is much appreciated thank you
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Build it stock. Summit has nice brass copper original fit radiators
fast 99
Spokane, Washington
If that's all you have try to buy a donor truck to rob parts from. Buying individual items will get expensive real quick.
WFO
Texas Panhandle
Welcome from up in the Panhandle.
I'd go mechanical too.
Punctuation wouldn't hurt on future posts, for ease of reading.
animal
Lee
c10 silverado
350ish
:welcome:
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
Tonimus
Phoenix
Tony
C10 Suburban
Welcome! Even on my race car I run a mechanical water pump. I'd suggest starting a project thread for general help or threads in daughter forums for specific issues.
SQ HAF KRU
Surprise, AZ
Greg
1/2 Ton Crew Cab
Gen V LS 5.3
Welcome to the team!!!!
I would do a stock water pump, electrics waterpumps work very good on race cars, but can be a problem on daily drivers. Most salvage yards will have the needed brackets to finish out your accessory brackets. Stock radiator, with electric fans should cool the beast, your Kwik wire set up should have provisions for the fans. Make sure you use relays for the fans, and mount then close to the fans. Keep posting your progress.....
86 C10 Shortbed
Ohio
Mark
5.3L
Welcome from Central Ohio.
86joshua
