- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
Saw your posts, but I’m not sure if you have a question about the dual tanks or are trying to post an answer. AFAIK, the old 6 port solenoid with only a single electrical terminal is still not available. Switching to the multi-wire 6 port solenoid requires some new wiring, but then you can just order the solenoid.
