Installing a New Exhaust System Including Headers
Normmus
Saskatchewan
Norm
I am installing a new dual exhaust system on my stock '77 K10 to replace the swiss cheese straight pipe. I am also installing long tube headers. I have the passenger side header bolted in and the collector flange is touching the driveshaft. Any tips on bending it to clear? I am reluctant to heat it much because the header is ceramic coated.
3 Ton
Pacific Northwet
Fred
1978-79 78 body, 79 gearing
K-15 Suburban
Going the wrong way. Single with a Magnaflow torque master will deliver more low end for off roading than a sheet hotrod set up. I had what you are building. I ripped it all off and have low end power up the wah zoo.
SquareRoot
I agree 100% with Fred. And, I'll add the Hooker Cast manifolds are even better. But, I doubt the OP is going to change course at this point if he's spent big bucks on Ceramic Coated Long Tubers.
Normmus
Saskatchewan
Norm
Yeah that ship has sailed already, just need to move the collector over about an inch.
Normmus
Saskatchewan
Norm
Just going to get a different set of headers
What brand headers are hitting the driveshaft? I've owned many and the driveshaft is not a clearance issue I've ever had.
legend57
San Jose, CA
Rob
I used the ceramic Headman long tube headers and they fit very well. I also used the Walker exhaust kit and it all fit nicely. I just replaced the connectors with some better quality ones.
I had to use the Headman headers because they were the only ones with the AIR tubes and were CARB certified. (At least, what I could find).
77Dmax
vt
Joe
Summit branded parts are usually very poor quality. I have had luck using a ratchet strap to pull on headers to move them around. Just beware that the shaft will move around in every direction, not just up and down.
Normmus
Saskatchewan
Norm
Just wanted to update this thread, I wound up installing Flowtech long tube headers which fit great, and a Thrush dual exhaust kit which included mufflers. The exhaust kit needed modification, but the truck now sounds great, way quieter and far more enjoyable to drive.
3 Ton
Pacific Northwet
Fred
K-15 Suburban
When I ripped my headers off, I found 1-2 spark plugs jammed in the collectors.
It seems when they dropped them, they just left them there.
So if your determined to under torque your rig, what out for flying spark plugs.
75BEASTK20
B.C. CANADA
Cal
Me either, and I've had every make out there. Definitely not the right header to be that close to the drive shaft. If it were just the pipe, you could 'squeeze' it a bit but a new set of headers is the way to go. Stainless 304. Trust me........they're worth it in the long run. If you're gonna flip the truck and sell, buy the cheapest ones, burn off the coating and then high temp silver spray paint. It'll look expensive, but isn't.:)
Normmus
Saskatchewan
Norm
You've been fortunate. The headers I bought were correct for the application but were a bit crooked where the collector was welded on. Resulting in the driveshaft being in the way.
75BEASTK20
B.C. CANADA
Cal
Come to think of it.................I once had yet ANOTHER '75 Chevy that had a slightly twisted frame and that threw EVERYTHING hilter kilter. Maybe that?
bryanedge117
