Distributor will hit edelbrock 3764 intake
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
The distributor will hit the mounting post for the coil, as this post sits higher.
New distributor is same height as old.
I might have 3/8-1/2" if we have to advance distributor timing.
Anyone run into with this intake?
Rickf
Grafton NH
1974, 1954 & a 1937
Are you not able to set the ignition module on the other side of the post?
JD Miller
Augusta, Georgia
JD
472 Cadillac
what kind of Distributor is that?
Nardulli
St Louis
C15
you can move the distributor one or two places on the cam gear. Set the engine at TDC on the compression stroke, move the distributor, note where the rotor is, and make that post number 1. next one clockwise is number 8, and so on.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
The distributors were typically installed when new, with the module connectors pointing more towards the firewall. Doing that will provide the needed clearance.
Yes sir, that's what I saw from my saved pics. I had e builder stab it.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
So here was the original, and I hoped new dizzy would line up same way.
@Nardulli
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Hmm, move dizzy on cam gear. So remove and reinstall 1 or two places counter clockwise? But engine is at TDC, and then rotor won't be pointing to piston one?
I am hearing that we can make which ever post we want #1 and go in firing order.
I am not getting how to get TDC and rotor pointing at piston #1.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
No sir special shape and cap fits that.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
The dizzy, ignition module needs to be pointing more toward firewall. I've just never stabbed one and trying to make sure I understand it.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
A pic of the dist from my truck, for your reference , sir :33:
On a Chevy V8, you can orientate the dizzy wherever you want AND have the #1 post be wherever you want. Just set the engine to TDC and drop the thing in wherever you want, but making sure the rotor is where you want it to be as well. The only tricky part is turning the oil pump drive shaft to match where you want the rotor to be pointing.
But yes, you can simply designate a different post as #1 if you don't want to reinstall the distributor or care that it's designated differently from typical.
Tdwmaxwell
