Doppleganger
OH-MI: Just like it sounds
I mounted the block off panel for all the heater core holes I wont need anymore. Used 3M panel adhesive with 1/8" screws to hold it in place, then used a stud welder to plug the holes once it had set up. Taped off and got about half the seams sealed with 2K seam sealer, including the block off panel. Also had the 2 large heater hose holes, a few screw holes from a gun rack and running boards, and then 16 holes on my bed/tailgate from tie downs all welded shut. Sanded the whole cab again for one last shot weather-wise first of next week of epoxy primer. Bottom needs sprayed along with the areas I sanded from all the welding plugs. Then it sits til Spring. Panel blends and looks better in person than the pic. Once everything is covered again alot will disappear.
Auburn, Washington
Yeah that month and a half is brutal. Lol
I get it. The struggle is real. Lived in Phoenix for 2 years. First winter I ran around in shorts and flip flops all winter. 2nd year I wore a hoody and thought it was chilly sometimes! Lol.
Although I resisted the urge to switch to winter oil after the AC didn’t kick in for a week! Haha all in fun. Cheers
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Drove it today to run errands(which was actually quite fun) and pick up an extra yard skeleton. So, drove it and decorated for Halloween/neighborhood zombie run.
Normmus
Saskatchewan
Norm
I haven't driven the 77 K10 much lately, and when I most recently drove it, the front brakes were dragging badly, but intermittently. Changed both calipers and bled the system and she's running great again.
mxer147
Colorado
Jack
k20
I hung the passenger door, welded some on the inner fender lower support and put the rear wheels back on so I could move it back four feet. It’s nice to have the doors back on since they were leaning against my super tenere for the past year. Perhaps I will get a nice afternoon for a ride. I’m still trying to finish the paint before winter.
Dravec
Ft. Worth, TX
Monte
R1500
Recently got her titled in my name, and called the dealership today to see if there was any chance they could find the correct key code for her, as I can't seem to locate even a single set of the keys for this girl. Welp, as expected, they couldn't go back that far, but they referred me to a locksmith that they work with, and since they referred me to him, he can make a set of keys to fit the existing ignition and lock cylinders. So I'll be investing that $220 or so in the next couple of weeks, then having her towed to my house.
Ajax19
Socal
Ajax
(Edit: better video version)Haven't done anything been working on other stuff(fords mostly lol) but got a quick clip doing a flyby unfortunately timing was bad because a Tesla was in the way
BRetty
Los Angeles
Franklin
If you wanted to DIY the lock change and save $$$, an new ignition lock cylinder can be ordered for ~$25, and a package with a pair of door locks would be $50 max.
(I bought my square with no door keys, changing that cylinder was the first thing I did myself. Door and ignition each require a special tool, but how-to info can be found here or many other places.)
If it's way easier to have dealer/locksmith handle it, here's some still handy advice. There are 8 different GM ignition key blanks, GM used a letter code from A-H. If you want to make spare keys later, you will need to know the right blank code and order those blanks -- nobody will have them on hand. Ask the locksmith to write down the blank code for you.
BRetty
ChuckN
Bellinham, WA
Chad
Got to work on the valve seals. Then I discovered that for whatever reason (probably because they decided to stick with just o-rings on the exhaust valves) they didn’t machine down all of the valve seats for press-on seals. I could measure, but it wouldn’t make a difference. Some slid on, now I’m running into some that are damn near the same diameter of the seals themselves. No rhyme or reason.
Then I discovered I couldn’t find the Pioneer umbrella seals I have somewhere- probably ferreted away in the shop. I took it as a sign to walk away for the day.
I did get a chance to try this tool that worked awesome for getting spark plugs under tight headers. No more futzing around with an open end wrench with #5 and 6. Just gotta be gentle since there’s no rubber grommet to protect the porcelain.
brentjo
