Kilian
- Mar 25, 2018
- Wisconsin
- K
- C2500 on its way to a K2500
I'm in the middle of a QJet rebuild and have a couple of questions.
The carb that I'm using does not have electric mixture control (blue connector on air horn) but it's missing the black plastic insert that is shown being used in place of the mixture adjusting solenoid. Is this insert needed or something that would have sometimes been left out at the factory? Not sure if the carb has been apart in the past to know if a PO just discarded it.
How do I check the electric choke for proper operation? Can I use a battery charger etc. to apply power and see what it does?
Thanks for the help.
