- Feb 24, 2020
- Auburn, Georgia
- Zach
- Sierra 1500
Can you use a small block PS pump on an LS bracket? I don't think you can. But that's what the motor came with, it's out of an '06 Envoy Denali. Was originally gonna use an LS truck pump but found out the whole alt/PS bracket is different, the bolt pattern is different for the pumps. I think I will source a truck bracket and convert it in the future though. I never considered failed motor mounts/sagging and causing that problem when I built the truckWhy the weird trailblazer PS system instead of just the stock PS pump from the original motor? The pulley shaft(and pump as far as I can tell) are identical between my original K25 PS pump and the one on my 2011 Burb and the L9H donor motor I bought. They were all interchangeable.
