Girth
- Feb 25, 2023
- Olympia WA
- Garth
- V2500 Suburban
Ugh... googled, can't find much info on that product. Seems that TDS is missing the rest of the info, that would cover topcoating it.Not much. Just heard this today, along with a '72 hr window' (was someone who does ALOT of higher end paint jobs too). I had always expected to have to scuff or sand it before high build primer, but never heard that it wont stick to 'cured' epoxy. WTF are you supposed to do - primer, seal, and paint all in one day? Only been 24hrs so I'd like to know if this is true or hype. I've known cars that sat in epoxy (covered) for years and then scuffed and finished. Dunno.
I'd assume scuff/clean/topcoat, after it cures. Can't imagine it's different from most every other similar product. My TDS says....
Time to Topcoat
(Primer Option)
• Allow a minimum of 1 hour per coat
and a maximum of 24 hours at 75°F.
• Between 24–72 hours, primer must
be sanded prior to topcoating
• After 72 hours, primer must be
sanded and recoated with a single
coat prior to topcoating.
That's a Lumabase DTM epoxy though. Can't imagine yours is THAT much different?
