fast 99
- Dec 31, 2021
- Spokane, Washington
- Brian
- K20
You just made confirmed my case for using a shunt. Very easy to exceed 10 amps.Some items in vehicles don't have a draw until after they have been powered up. So you have to unhook battery, hook up meter,amps, turn on key, turn off. If your meter only does 10A, make sure you don't have a bunch of crap turned on when doing this, -heater, wipers, etc, bot DO turn on radio, especially if aftermarket. This is why mechanics use a battery switch, install it, run vehicle, turn everything on, turn truck off, hook up meter across disconnect switch, open switch. This way everything gets activated.
Will add a majority of draws I have seen were caused by aftermarket items, such as alarms, remote start, radios, amps, ect.
